DarkenReaper57
- Oct 2, 2003
Right now, im trying to make my own w/c system, but i am on a limited budget. I want this to be a more DIY thing, although i dont want to get in over my head. It must also work on an A64 and radeon, so when i upgrade, i can use it (i dont mind it if i'll need to buy some adapters for waterblocks).
Here is what i'm thinking of getting so far:
Danger Den TDX or D-Tek Whitewater (dunno which)
Maze 4 GPU block or D-tek GPU block
Eheim 1250, Hydor L35, Mag 3, or MCP600 pump (leaning towards the 1250 for price/performance/reliability reasons...i dont want the thing to leak)
Danger Den Double Heater Core, or something similar (suggestions welcome)
Insert Res here, no big deal.
Tubing, either clearflex or tygon
The CPU Block:
What would you guys recommend for performance and Socket A/A64 compatability? I'm seriously looking at the whitewater, since it has a a64 mount kit that i can get when i upgrade later.
The GPU Block:
I researched much here...but i'd like to find a relatively inexpensive high performing block that will work on my current gf4 4600 and will work on a radeon 9800 or x800. I dont mind if i need to buy some extra clamps or whatever later on.
The Pump:
Ive done a lot of reading here, but its difficult to make a decision. Since the whitewater is not a very restrictive block (i hope i am correct here) i would want a pump that delivers more gph than head. I like the MCP 600, and hear good things about it, but it is a bit pricey...
The Heater Core:
First, do you guys think it would be cheaper to get a double heater core from autozone, one like this: http://dangerden.com/images/heater_core/dbl_heater_core_lg.jpg and put barbs on it for 1/2 '' ID tubing, and make a shroud and get a 120mm fan or two for it, or:
Just buy one from that link provided, and make my own shroud and buy fans, or
Simply buy a complete heater core with fan and shroud.
Also, is there a noticable difference between the cooling ability of a heatercore and a double heatercore. Does the extra price justify performance?
The Res:
No worries here, ill just order something online, make my own, or make a T line.
The tubing:
Tygon, silicone, or clearflex? My case isnt huge, but isnt small either, its a med sized ATX, of that helps. Does one type respond better than others to bends? I dont want a kinked system.
Thanks a ton for any help and/or suggestions.
The CPU Block:
The GPU Block:
The Pump:
The Heater Core:
The Res:
The tubing:
