Buying vista now question...
Kingpin
I heard that you can buy a M$ Technet subscribtion for $350 and get Vista Ultimate with a legit key...If true is this worth it?
Keep in mind Technet is a annual renewal. If you get for just Vista then it might not be, but if you had extra computers and want to evaluate and practice and use Exchange, Windows Server, and other included software and get access to lots of good information then it is worth it.
As an IT Manager I find Technet an invaluable tool.
Thanks for the reply back, I am just interested in Vista and maybe Office07 to. Right now Im on RC2 and find Vista to be rock solid for me. I was planning on buying Ultimate anyway and this is a option to get my hands on it now and save about 100 bucks. I dont plan on renewing so I didnt see any real downside to going this way, as I am not a IT guy. Thanks
Google is more valuable as a tech tool than technet. And everything that is available (sans a few hotfixes only available to the general public through MS support) is readily available online @ technet. Still I can't knock it for $350, you get the software that you want and you get a hard copy of everything on the web for technet.
I have been running both Ultimate and Office 07 thru my companies MSDN sub (Office just became available). Both are nice and stable thus far.
An oem upgrade version of Vista ultimate should be available as soon as Vista launches in Jan, for $259. If you actvated RC2 it's good until June 07 and you can sign up for Vista updates on the technet website. By then there will be other promos I'm sure. RC2 key is good for up to 10 activations,so you can run it on up to 10 machines at once. The only downside I've found is trying to find a reasonable priced printer that works and is STILL available. Cannon has a lot, but the numbers in the add hardware section don't seem to be still available.
Now with technet can you also use the key on upto 10 pcs at once? Thats what I heard but wasnt sure if that ment at once or with each activation it kills the one before that. I have 3 pcs here at home and would like to have all 3 run vista, without buying 3 subscriptions. If not oh well.
OEM Vista is supposed to be available at or right after launch.Just get a hold of RC 1 and load it on all 3 machines. I'm not sure about the technet deal, but thats pretty expensive, if you aren't a developer or IT. RC1 is pretty stable as long as the pc you load it on is up to the job. Visit MS website for Vista and download a copy of the upgrade advisor and see what the report says. Basically its a 2.0 or better cpu 1 gb of ram and at least a 128mb video card 256 being even better. I'm running 2 gb of ram and a FX55 cpu along with a 256 mb Video card . It ran pretty good on an NF2 with a 3000 Barton and a 128 mb video card too. Anything smaller, it runs but not very well.
Same. Lotsa neat new products to try, including Groove server which may be something I really need to look into to get rid of this shitty First Class mail server and migrate to Exchange.
Not to hijack, but can someone suggest a Microsoft subscription service? I'm an IT Manager of a small company, and I'd like to have access to single copies of the software mentioned in here for testing. We don't spend a lot of money on software, so I'd like the ability to test everything before we buy.
djnes, as an evaluation tool Technet is a great tool that would do just what you need. Just remember for production use you will need to purchase a non-technet license.
As far as software purchases, if you buy for than 5 copies on your first order look into an Open Business License (entry level volume license). Software assurance can provide some additional benefits as well.
