OK, I am getting pretty much everything i need from xoxide.com. This is all for my b-day on march 4. I am waiting for the x-hour to order just to make sure the prices dont go down.
Here is what I am getting:
http://www.xoxide.com/tttsunami.html Thermaltake tsunami case
Dual blue cold cathode kit
Ultra X-connect 500w
http://www.xoxide.com/nibbler.html Nibbler(will this work to cut out the default thermaltake fan grills so I can put my own in?)
http://www.xoxide.com/rocker.html (3x, I am planning on using these to control my cold cathodes and the little LEDs on the front of the tsunami, will this work; I know how to solder fairly well)
http://www.xoxide.com/18awgwire.html (for the switches I am going to make, ordering 12 feet so i have plenty.)
http://www.xoxide.com/thumbscrew1.html Extra thumb screws never hurt!
http://www.xoxide.com/120mmfangrill.html (2 120mm fan grills, and 1 92 mm, just didnt feel like linking to the 92mm)
http://www.xoxide.com/zachco.html zalman chipset cooler.
http://www.xoxide.com/arcticsilver5.html Arctic silver 5
Anything else I should get? What do yall think about all this? any other mods I should do? I will also be getting a cheap multimeter to test my rails. Anyone who has been in xoxide during x-hour, do you think the prices will drop on any of the items i listed?
Thanks,
Sean
Thanks,
Sean
