heatlesssun said:With the Forceware 80 drivers, you only need the same GPU model. So you in theory can pair any 7800 GT with any other 7800 GT, even if they are two different brands or even different memory sizes or clock speeds.
I however, just to eliminate any potention problems, would by the extact same card, if at all possible. SLI will only work to the lowest common denominator, so if you got a better second card, a little faster or more memory, SLI will treat both cards as the slowest and smallest memory size of the two.
You can check out the info here in the Configuration Secion of SLIZONE: http://www.slizone.com/page/slizone_faq.html
Good hunting!
_____________________________________________________________
tor
