So we are replacing the 32'' HDTV(which i am getting for my PC ) with hopefully a same size replacement since we cannot afford HDsat.
What do you guys recommend i do? The only SDTV i see on newegg is http://www.newegg.com/Product/Produc...82E16889115008 this one, and it seems awfully overpriced, as i can buy a 22'' HD for the same price..
So i was wondering if i should buy it used, or if there are any sites that sell them reasonably priced..
