Buying Questions
Inn3s
So I was tossing back and forth the idea of getting a laptop for school since I will be leaving in the fall. But now i want it as soon as possible, so i have justified getting one for the summer so that i can do work wherever i go. So then I was looking at ASUS vs DELL mostly and in the end saw DELL giving me a better "Bang for the buck." THEN KATANG! Santa Rosa cores are released today. Now today dell's 500 dollars off coupons expire.
Also the company i work for is still using an old version of access, 97 (ghetto i know) I believe. It wont work with vista will it. Should i just get a 9400 with XP on it?
Do you guys think that I should stick it out and wait for some good Santa Rosa stuff, or will it be to expensive mid june anyways?
I will take any advice I can get. Thanks!
