Buying new Pc and need help
HiCZoK
Hi to all. Here is what I'm want to buy:
-Asus/Msi 8800GTS 320mb
-C2D E6300
And that is all I known :) I need you help with MoB and Ram
-Good and cheap(!) Motherboard (maybe Asus or Gigabyte)
-cheap(!) 2x512 of What ram ? Or maybe 1 gb ?
I spend all my money to Procesor and Gpu so that is why MB and Ram must be Cheap but still good .Thx
Budget? Do you plan on OC'ing?
I'm going to assume you plan on OC'ing. Since you want cheap, go for the Biostar TForce 965P ($105) or Gigabyte GA-965P-S3 ($109). They're both great budget boards.
As for ram, how far do you plan on OC'ing? Theres some G.Skill DDR2-800 2GB sticks for $170, model 2GBNQ. However, if you drop to the E4300, you can get some DDR2-667 sticks instead, which are much cheaper. The higher multiplier of the E4300 helps with overclocking. The E6300 could typically reach higher than 3.2Ghz, but the E4300 averages only around 2.8-3.0Ghz.
E4300: 9 * 333 = 3.0Ghz, DDR2-667
E6300: 7 * 333 = 2.3Ghz, DDR2-667
E6300: 7 * 400 = 2.8Ghz, DDR2-800 (DDR2-667 can usually be OC'd to reach this speed)
E6300: 7 * 433 = 3.0Ghz, DDR2-866 (DDR2-800 can usually be OC'd to reach this speed)
E6300: 7 * 500 = 3.5Ghz, DDR2-1000 (You'll need Micron IC's to reach this speed with DDR2-800 ram)
The E6300 requires better RAM to reach high speeds, while the E4300 can reach 3Ghz with only DDR2-667.
$163 - Intel Core 2 Duo E4300 Allendale 1.8GHz 2MB L2 Cache
$184 - Intel Core 2 Duo E6300 Conroe 1.86GHz
Mobos:
$105 - Biostar TForce965PT, LGA775, Intel P965 Express
$108 - Gigabyte GA-965P-S3 Socket T (LGA 775) Intel P965 Express
if you get the E4300:
$136 - OCZ S.O.E 2GB (2x1GB) DDR2-667 OCZ2SOE6672GK ($156 - $20MIR)
if you get the E6300:
$170 - G.Skill 2GB (2x1GB) DDR2-800 F2-6400CL5D-2GBNQ
or, for higher overclockability:
$190 - Patriot eXtreme Performance 2GB (2x1GB) DDR2-800 PDC22G6400LLK ($240 - $50MIR)
$190 - Buffalo Firestix 2GB (2x1GB) DDR2-800 FSX800D2C-K2G
If you plan to go higher than 3.0Ghz, you'll need a better HSF than the Intel Stock cooler. Go for the Tuniq Tower, Scythe Ninja/Infinity, Zalman 9500/9700, or Arctic Cooling Freezer 7 Pro (NOT from the egg, should be around $20, shop around).
