Buying DVI Cables
Ladic
I currently have one of those HDTV cable boxes from comcast plugged to my HDTV with component cables, I would like to get some DVI cables to get the best picture possible, the problem is where can one find good affordable cables? at bestbuy and other stores they are no cheaper than $50, which seems extremely expensive.
I'm looking at DVI - D dual link, since that seems to be the connection type behind the cable box.
Do you guys think this cables here will be any good?
and will the picture on the TV improve greatly over component?
http://www.dcables.net/index.asp?PageAction=VIEWCATS&Category=106&engine=adwords!4980&keyword=%28dvi-d%29&match_type=#DVI-D%20Cables
monoprice FTW. i just bought some more cables from them the other day; outstanding quality for next to NOTHING.
go. now.
