Buying a refurbished computer, have questions
ir0n_ma1den
I am thinking about buying a debranded computer but I need to know if the following will be a problem:
# OS and documentation are NOT included
# Device Drivers not included (Drivers may be difficult to find)
# Burning software not included
# DVD decoder not included
well it will be a problem in that
1, you need to buy an OS
2. you need to find all the drivers, which means you need to know what parts are in the computer specifically
3. You will need to get burning software if it has a cd/dvd burner
4. VLC player.
any reason you are buying this specific computer? where are you buying it from and for how much ?
what are the specifications on the hardware
As long as the drivers are available online, you should be fine. Oh, and make sure its good quality parts, lol.
