Buying 5.1's.. some questions
j3ff86
I'm planning on buying the Logitech X-540s; is it possible to get extension cords for the back two speakers? What kind of cable should I look for? And second.. where can I find some speaker stands that will work with these? Thanks :D
The cables for the rear satellites should already be fairly long, but they look like RCA jacks. You might be able to use an M-F RCA cable to do it. I doubt you'll need to.
There is already some sort of base attached (possibly one that swivels for hooking on a wall?). Speaker stands may not be entirely applicable. But you can probably work something out.
