Bus Lock?
ho72
Is the function that keeps the PCI and SATA buses within spec when increasing the FSB built into the chipset or is it a feature supplied by the mobo maker? I have a Tyan K8E with the nV4 chipset and an Athlon X2 4400+. I realize that the mobo and the CPU are not the best OC tandem, but I'm just curious what will happen if I bump it a bit. However, if there's not some way to know that I'm not jacking up the bus MHz in the process, then I won't do it.
Thanks.
