Burst vs. Avg Read Speeds ?
BassKozz
How does burst speed impact disk preformance?
How does average read speed impact disk preformance?
Can someone explain these two readings from HDtach ?
Thanks,
-BassKozz
burst speed is basically read speeds from the cache of the disc, avg read speeds are the average read speed across the entire platter.
Here are 2 of my Raptors against each other...they are pretty close to each other eh?..:)
..what kind of discs are you using, and in what array?
Im guessing a RAID 5..based on the results you got..
serbiaNem said:
Why is the random access time so different between your raptors?
Different firmware.....The 00FLA2 revisions are known to be a little faster...
So burst speed doesn't really matter in the long run... only Average Read speed... correct?
Yes it is a RAID 5 array:
LSI MegaRaid i4 Controller card and 3x 400gb Seagate HD's
Thanks
Correct on the average read speed being more important than burst speed. Which would you rather have? I drive that bursts 600 MB/s for 1/2 second and has an average speed of 30 MB/s or a drive that bursts at 100MB/s for 1/2second with an average read speed of 80 MB/s?
Great, Thanks for the help defakto :D
