smodtactical
- Dec 26, 2010
My Burson device that I purchased January 2015 has stopped working. I believe it may be a problem with the device not being detected by windows. When I try to reinstall the drivers they tell me to connect the burson device and after disconnecting and reconnecting it it just does not detect it and says no device detected.
I am using windows 10 x64 and I used the device for about 1.5 years without problems. Nothing changed about my setup or the device itself. I tried it in multiple usb ports and same issue. I also tried to swab the DAC since I own both and that didn't work either.
Does anyone have any suggestions? Thank you.
