Tony Montana
- Sep 11, 2001
Has anyone ever heard this word? It has been explained to me that you need to burn in a CPU at a certain speed before OCing more? Is this correct or can you CO right to the speed you want?
Funny... I always thought that the main purpose of burning in was to test the processor's stability. The logic behind it (as I learned it... feel free to correct me, though, if I'm wrong) is that the burning in process (often done through a benchmarking/diagnostic program such as Sandra and Prime95) was simulating the CPU at full load for at least a few hours, and that if the CPU could handle the stress caused by the burn-in, then it should handle nearly anything else. It was often done after the processor was overclocked to make sure that the CPU could handle a full load in its new settings.MooCow said:Some people might say that burning in is just a myth... its debatable.
I believe running Prime95 or Sandra is to test the stability of the system... burning in is rather making it run hot in hopes of boosting performance. I think... now you're all confusing me.tiraides said:Funny... I always thought that the main purpose of burning in was to test the processor's stability. The logic behind it (as I learned it... feel free to correct me, though, if I'm wrong) is that the burning in process (often done through a benchmarking/diagnostic program such as Sandra and Prime95) was simulating the CPU at full load for at least a few hours, and that if the CPU could handle the stress caused by the burn-in, then it should handle nearly anything else. It was often done after the processor was overclocked to make sure that the CPU could handle a full load in its new settings.
Since I don't overclock, I can't call on the validity of burning in after an overclock, but I've always burned in my processor after the intial build of each rig that I built. I haven't had any CPU-related problems in any of the rigs that I built, but that may be more attributed to luck than anything else....
