Burning .m3u files
Status
Not open for further replies.
anotherguy159 said:
Any 'm3u' is a playlist, dude....
Yeah, but when I download a song, it it saved as a .m3u file. Do you know whats the problem? Thanks.
Edit: I found the Solution: Thanks for your help.
1. If you are going to download music, don't suck at it. Figure it out.
2. Did you try...renaming....the file? :rolleyes:
3. Are you sure you are downloading a 'song?'
4. This site, http://myden.ubernet.org, may assist you.
Good luck you warez child.
Status
