hello, im sure most of u are familiar with Nero, nero vision and maybe other burning tolols like dvd santa. recently iv been having probelms with my laptop when it came to burning dvd's files, after transcoding and after burn." AT EARLY STAGES IT WAS FINE" untill 6months after, now i cant seem to burn things correctly and what i mean is files sometimes burn to 80% and fails.. or maybe it burns 100% pops out states all good" i try to run the dvd.. fails...
another issues would be when after converting files to dvd after it burns its all done again. but the cd is BLANK! wasted " or burns a few movie files and works and lets say 3/5 files work, on the 4th episode it freezes, iv been using nero-nerovision 7" on my WINDOWS vista and it has been 100%!! fine. maybe my dvd burner is screwing up???? i dont get it, it reads CD's perfecly??? is buring a cd and runing a CD different?? i swiched to nero8 same problem and all other dvd applications screw up as well. i think ima goona take it in for a check, please dont advise me to use some other dvd burning tool, coz it wont work!
thanx for reading. cheers!
