Hey guys..
On my old computer, whenever used the computer while I burnt a music CD, it would turn out horribly, and skip all the time. The only solution was to either
a) Write on max speed but leave it 100% alone with nothing running the background
b) Write on a very slow speed.
Now, I got a whole new computer, but I'm using the same burner. It's much better, but it still gets messed up when I'm actively doing a lot of stuff.
Movies and data are (or appear to be..) fine, but music skips.
So, is this a burner issue? The CDs I use (Sony regular CD-Rs)? The RAM (currently using only 2 GB, going to buy 2 more soon)? I don't think it's the CPU as I got the quad core q6600. Running on Vista.
This is the burner I have, it's a bit old but I'm not going to replace it if it's not the problem.
http://www.cdrinfo.com/Sections/Reviews/Specific.aspx?ArticleId=14845
Thank you
PS. Anyone running Vista have a cannon camera? I've tried two differnt ones (one is brand new), and it can't find drivers for it. I download their stupid software, and it still won't load... can't find the camera. Not really sure what to do.. I don't want to have to buy a memory card reader but it seems I may have to since canon didn't seem to bother making a working Vista driver
Thanks.
Thank you
Thanks.
