burner help!
Suki243
i have a memorex burner that only burns dvd-r so i decided to buy a tdk dual format burner, i bought one for my bro, i put it in my computer and when i start it up it doesn't get past the part where xp goes and that little bar goes by, it just keeps on goin on and on, so i decide instead of hooking up both burners i will hookup only 1, so i only hooked up the tdk, and it got into xp and everything worked, and also with the memorex but how come both don't work at the same time?
