Burner and Hardrive on IDE, Help Please
Sharik
Sup all, I got this problem where if I put my hard drive on one IDE cable together with my cd burner, my comp will only load to the Windows loading screen and then just hang there. I can't put my burner on a separate cable as its taken up by a dvd burner and dvd reader. I tried messing around with jumper setting between the hard drive and the cd rom and so far no luck. However if I start windows in Safe mode, it all works well. :confused: My friend told me that my only way is to buy an IDE cable with 3 sockets and put my two dvd's and the cd burner on one cable and just leave the hard drive on its own. I think you guys might know of another less...costly... way to solve my problem... I am open to all suggestions and thanks in advance. :eek: :)
Your friend is wrong. You do not want to put 3 ide devices on a cable. They will not work ide can only handle two devices per channel.
You should be setting it up like this
(harddrive jumper set to master)----(optical drive jumper set to slave)----(motherboard)
If you've got it any other way it is probably causing your issue.
nope, didnt work, now the comp just restarts when gets to windows loading screen...
I guess im screwed beyond repair... :(
What happens if you just unplug the DVD entirely? I guess it could be causing a conflict.
How about a live Linux cd? If that works, your Windows install could just be broken. Knoppix is easy to test with.
Can you get it to boot with just the hard drive?
Try to eleminate variables. add each drive until it locks. when it locks that the problem.
And you don't need a cd burner and a dvd burner.... the dvd burner will burn cd's too. :D
All you need is a hard drive on IDE-1 as master. A dvd rom on IDE-1 as slave. and put your DVD burner on IDE-2 as master. Toss the cd burner. You can't have both optical drives on the same IDE channel and get full throughput when copying CD/DVDs. It just doesn't work well.
I already figured out that my problem is having a hard drive and a cd-burner on a single IDE. I did that by disconnecting the dvd burner and reader entirely and seeing that the comp will still freeze at the windows loading screen. But what bothers me is that I CAN start it in safe mode with all drives connected. Maybe it's a software error rather than hardware... :confused:
He's right you know, DVD burners can burn CDs.
Yep, sounds like it's time to reinstall windows. Try it with a different drive if you've got one to see if it's windows in general or just this one install. If you can get it going on a different drive, then it's probably the specific installation, and overwriting it will fix the problem.
Try doing a repair install instead of a wipe, it should put you back to a decent starting point and not lose any software you'll have installed on teh system.
Whoho!! :D Guess my burner and hard drive didn't want to be friends after all. When I swapped the burner with a dvd drive and it all started up ok!
Thanks all for the help.
Conclusion: Dont put a 160GB WD and a Plexwriter PX-W482ATA on the same IDE cable, they will not work together. :cool:
Glad you solved your problem.
You could always put an ATA expansion card in for cheap that would give you quite a bit more flexibility with placement.
