Burned first dvd, got questions.
bandit390
I just got through buring my first dvd using dvd shrink and dvddcrypter. I removed some of the sound packages and about 5 minutes of the end of the movie. Now when I played it in my dvd player, it just striaght played. None of the previews or options at the beggining of dvds.
Is this just how it is or did I do something wrong?
if you re-auther it you cant save the menus as far as i know
Some others are saying there start up like a normal dvd.
Heres what I do....
I first load it into dvd shrink => re-author => compression settings => Remove some audio files => Remove credits at the end => click on backup = Starts encoding
Above = none of that beginning stuff.
What am I doing wrong?
