Burn in software help
ochadd
There is a piece of software I used to use for burning in new PCs. The screens are red with a big on and off switch and a gif of a guy hammering a CPU or something. Think it ran prime95 type of test and also stressed GPU. Might have had a russion name... Can't think of the name and google/search is failing me. Any help is appreciated.
Humm, never heard of it. Most of the current ones recommened are Prime95, LinX and Intel burn test.
The only burn in I can think of is Prime95, LinX, and Intel Burn Test for CPU. For GPU there is OCCT , Furmark, MSI Kombuster, and Heaven
OCCT is the app I was thinking of. Thanks so much.
It does CPU, GPU, and memory with graphs. Nothing it passed on has ever failed at least. Not that anything else is better or worse but I've had good luck with it.
