Strangely enough I have observed the same thing with my 2 gigs of Corsair XMS ram. The stuff sucked harcore out of the box, but every few days it is able to take bump in speed. Now, I have not observed the same thing with my 2 gigs of BallistixBigTaf said:burn in on bh5 ram isnt a myth
saw it first hand 220 out of the box 240 two weeks later with the same settings.
I really want to not beleive in burn-in, but i cant argue with the results, damned if I can find a way to explain it scientificly though.
(cf)Eclipse said:i'd do this:
memtest for 3 hours per gb of ram
windows memtest for 3 hours per gb of ram
run superpi 32m 2-3 times
run prime95 small-fft for 6 hours
p95 blend for 6 hours
loop favorite gaming bench for 3-6 hours
copy >3gb of files while windows memtesting and run MD5 hashes to make sure data is intact
that should be pretty stable. checks the cpu, gpu, ram, and hd's.
spine said:As far as cpu's are concerned, 'burn in' is a myth in what people usually believe it to be (some kind of electron migration that somehow improves the chip).
However, burning in of the TIM joint between the cpu and heatsink can have quite an impact on overclocking. With cpu die sizes getting smaller and smaller and the heat load ever increasing, the TIM joint becomes an increasingly critical area. You can probably gain 50mhz sheerly from 'burning in' a freshly seated heatsink over a couple of weeks.
