Burn-In Advice (New Build)
WolfpupNX
Heya - quick question.
Going to be building my new system soon (first build ever). Obviously I'd like to burn in/test for stability once it's done. I'll be running Vista 64. What's standard practice/best practice for burning in a new machine?
Thanks!
There is not much in term of a "break-in" period for a computer other than the thermal compound on the processor/heat-sink. Testing wise, you can use memtest86 to do a check on your memory modules and orthos or prime95 if you planning to test for stability when overclocking. That is basically all I can think of at the moment.
