I am technicly not done yet, I was going to seal the tops of the PVC with something, but like you said I could have done that in addition to adding an angle to it.
I know about the grounding part and gave it some thought, your right.... After reviewing my cruddy work I have decided to re-do the whole thing, I like to get it right the first time, not have problems down the road. What i'm going to do is just go to home depot or something and get some continuous flexible PVC stuff, like what is used for plumbing, so therefore there is no chance of water intrusion through joined parts. But thats not all! I will also run the cable that is at the trailer to the house so there will be a continuous cable from the pole to the house then at the house I can put up a temporary splitter at the house and run it to the trailer... And it will also be grounded. I'm kind of scared about the signal, it looks like the cable guy stretched some RG-6 from across the street to its current location.
Here is the signal the modem is getting right now:
Forward Path: Return Path:
Signal Acquired at 111.000 MHz
SNR: 31.7 dB (periodically drops to 28)
Frequency: 30.5 MHz
Received Signal Strength: -13.8 dBmV
Power Level: 61.0 dBmV
Bit Error Rate: 0.001 %
Channel ID: 5
Modulation: 64 QAM
Return path:
FRQ: 30.5 MHZ
Power level: 61.0 dBmV
Channel: 5
Modulation: QPSK
