bungled driver install =Blue screen,help!
TomEgun
was swapping a 7600 for a 7950 GT ,everything was going fine,hardware wizard found the card, when it went to look for drivers , instead of letting it find the shipping ones on the CD as recommended, this dummy pointed it to the newer 91.47 I had unzipped to the desktop, well it didnt like that ,stop error says video driver failed to initialize, put the 7600 back in, had to select "Enable VGA mode", in boot options, but then works fine, this didnt work on the 7950 tho, wont even let it boot in safe mode with the 7950 in there..... ideas?
Just format, in the time it takes troubleshooting you could have already installed all your necessary apps..
Use driver cleaner and then reinstall drivers.
