Hi lads,
since I may have some free time this weekend and I am getting my new case this week, I want to finally put my WC system together.
I have: Swiftech Storm block
I was considering to get the Apex Ultra kit and selling the Apogee Block
-or-
buying parts.
Since I do not own a drill, and the case I bought already has holes for a rear mounted radiator, I want to get something like the Radbox to mount my radiator outside. Is there anything similar from other manufacturer's besides swiftech? If so, how much and where do I get it from.
I can get a D4 pump for ~$60 from a forum member. Is that a good deal? Should I get the D5 or MCP655 (whatever the swiftech one is called) instead?
Would you generally recommend a specific store?
Greg
PS.: No TN, I am not getting Aquacomputer stuff, I do not have that kind of cash.
-or-
buying parts.
Greg
