I'm not sure how you believe this not to be a bad cpu.
According to you, its only good point is AES encryption. How many customers consider that their priority?
Also from you:
Honestly these were not ready for release
Bottom line, I wouldn't buy a FX cpu at this time
I don't see how after reading what you wrote that anyone can consider this a good cpu.
Well, its not a bad cpu, it just needs to mature a bit more. There are other things it does well other than just AES encryption as well. Basically anything that uses its instruction sets it starts to shine.
so yes I would not recommend anyone buy one at this time, however, this doesn't make it a bad cpu. It just means I think we will see these mature, and get better over time. Point being if you already have a am3+ motherboard and a capable cpu there is no reason to go out and buy the New FX. You might as well wait.
