Omegas
- Jan 19, 2007
my guess is this person isn't "new" but didn't want to put up his real alias incase these pix turned out to be BS.
Anyone know the Cinebench 11.5 scores for an AMD 1100T or 1090T at stock, turbo and even OC speeds for comparison? I'm seeing around 5.7's to 5.9's at stock speeds...Something seems off.
Over at XtremeSystems, they have a chart listing some scores for the Thubans:
1090T @3.2ghz = 5.64
1055T @3.4ghz = 5.95
Thuban core!= Bulldozer core
Wait......What!?
A whole bunch of Bullshit coming out of China or wherever,
LAMO once again let Intel leak some bullshit benches starting their corporate smear campaign.
What the hell makes you think that AMD would even want to leak some crap like this.
This same shit happens almost every new release. Man you people suck if you really believe this.
And those benches look like turbo is disabled on the AMD but not the Intel. Gee... that is really freaking fair.
I think it's worth pointing out at this point that this is like the third set of leaked benchmarkd we have seen and I know every time somthing is leaked here the cool thing to do is to cry fake as loudly as possible but all the leaked benches have pretty much shown the same thing namely bulldozer being a hughe step up from phenom II but still only equaling or beating SB in bench makrs that are heavily multi threaded and falling behind by 20+ % in all others.
were lloking at multuple sets of leaked benches that all pretty much show the same thing I suppose it's possible that its all a huge conspiracy but that sure seems unlikely. Now couple that with the constant delays and AMD's refusal to show us anything other than !!!Dirt 3!!! performance and it paints a pretty poor picture for bulldozer's ability to compete with sandy bridge performance wise.
I want AMD to succeed and I really want to believe that BD will be every bit as good as or better than SB but for me to actually believe that would require an act of blind faith on my part that is just not realistic.
Lets be real guys if AMD really had a chip on their hands that could crush SB at this point as close as it is to supposedly releasing they would be publishing bench mark results themselves and handing out early review samples to get people hyped for release not hiding and showing us games that would run just as well on an Athalon X2.
You can be sure it is not faked.
All seemed well...except the Cinebench scores were exactly what a six core Thuban 1100T would get at stock speed. That part is not "a huge step up from Phenom II". The FX-8150 has 8 cores. Cinebench also scales surprisingly well with more cores. The OP was also a 2 day noobie that joined just to post this thread...something seemed off. The rest of it seemed ok.
Once again:
Cinebench is a floating-point heavy Benchmark. Thuban contains more FP units than Bulldozer. Now call your facts. FX-8150 Bulldozer has 4 modules, you have two Integer cores in every module but you don't have two FP units in it. It's not a traditional Octacore where all units are exclusive for every core. That's why some of the insiders calling it Quadcore not Octacore. We will see how it scales. And with turbo enabled FX-8150 is faster in Cinebench than 1100T with less FP units. Not huge but easily faster at least.
Once again:
Once again:
No shit a Thuban core is not a Bulldozer core. I am very well aware of that. All I'm saying is it doesn't seem right that an 8 core/8 thread cpu from a newer generation performs exactly the same as a 6 core/6 thread cpu from the older generation on a benchmark that is known to scale incredibly well with more threads and cores. Combine all that with the fact that you just joined 2 days ago and all your posts are in this thread, "Bullshit" seems like the appropriate word to describe all this. I'm seeing 1100T's across the net scoring in the 5.9 range on cinebench 11.5. This FX-8150 that you showed scored a 5.93. That is the score that was posted before you took the pics down in a fit of rage. Honestly, I think you should have left the pics and link up. Then when the product was released, you would have been proven right. But since you pulled them, it seems even more fishy. If these scores are indeed proven correct, I will gladly admit I am wrong and back down.Once again:
Exactly... Unless the FX-8150 took a major step back in performance, something seems really off. Even if the performance of each core in an FX-8150 is exactly the same as a core in a Phenom II or Thuban, there are more of them.True, Thuban has more FPU cores. 6x 128 bit, Bulldozer has 4x 256 bit, ergo it can process 8x 128 bit code. So Bulldozer can process 8x 128 bit interger and floating point operations per clock, and Thuban can process 6x 128 bit interger and floating point operations per clock.
Not less FP units, it can act as two 128-bit FP units or one 256-bit FP unit unless I misunderstand how it is supposed to work.
Bulldozer -
"Two symmetrical 128-bit FMAC (fused multiplyadd capability) floating-point pipelines per module that can be unified into one large 256-bit-wide unit if one of integer cores dispatch AVX instruction and two symmetrical x87/MMX/SSE capable FPPs for backward compatibility with SSE2 non-optimized software"
Phenom II -
"■128-bit floating point unit (FPU)
■High performance (128bit internal data path) floating point unit per core. ◦Benefit: Larger data paths and quicker floating point calculations for better performance."
Bulldozer -
"Two symmetrical 128-bit FMAC (fused multiply–add capability) floating-point pipelines per module that can be unified into one large 256-bit-wide unit if one of integer cores dispatch AVX instruction and two symmetrical x87/MMX/SSE capable FPPs for backward compatibility with SSE2 non-optimized software"
Phenom II -
PII can do one 128 bit Add and one 128 bit Multiply per cycle, so the theoretical FLOPS of a PII core is equal to the BD module. BD is more flexible in that both of its 128 FPUs can do Adds or Multiplies and can be increase by 2X with the right algorithm and rewritten software that takes advantage of the FMA.Phenom II -
movaps xmm0, [eax+ecx] // 4 data movement instructinos (load)
movaps xmm1, [eax+ecx+16] // the other thread can use the 2 SSE pipelines while
movaps xmm2, [eax+ecx+32] // we wait for the memory controller to get our data
movaps xmm3, [eax+ecx+48]
mulps xmm0, [edx+ecx] // 4 multiply instructions
mulps xmm1, [edx+ecx+16] // now its our turn
mulps xmm2, [edx+ecx+32]
mulps xmm3, [edx+ecx+48]
movaps [edi+ecx], xmm0 // 4 data movement instructions (store)
movaps [edi+ecx+16], xmm1 // store the results and let the other thread use
movaps [edi+ecx+32], xmm2 // the SSE pipelines again.
movaps [edi+ecx+48], xmm3
I also wanted to add to my last post by noting that the other problem AMD has is that Bulldozer has been in development for so long that even if it comes out and performs every bit as well as SB Intel is literally sitting on multiple new cpu's that are even better than what they have now. The more I look at it the harder it is to believe that AMD will ever be able to catch up.
Now we know you are a troll. Thanks for removing all doubt!
Yes (4 FPUs but twice as wide to my understanding). So it's 8 Integer cores and 4 FPUs (which should act as 2x128 in Cinebench multithread). Thuban has 128Bit FADD and 128 Bit FMAC on each core. Eight exclusive cores with its own units should scale better. Depends on the workload. What I wanted to say is hat Cinebench may not Bulldozers best discipline because its FP heavy. You can't count it as 8 traditional core design until its clear how it scales with Bulldozer. Don't expect 95-100% scaling.
Thanks for confirmation that it's better to hide Bulldozer Benchmarks, some Fanboys goes crazy. Was a mistake to open a thread with BD Benchmarks here. Gonna ask a Mod to close this thread.
I want Bulldozer benchmarked while it's compiling Qt (all of it), or some other big C++ project. As long as it uses an SSD, the CPU should be fully loaded. C++ scales nearly perfectly.
If anyone wants to still see the benches, here you go:
http://www.chiphell.com/thread-250461-1-1.html
Seems the author(s) tried it on two different boards AMD760 and M5A97. As such, the results varied wildly. He's of the opinion that there's some optimization/ BIOS issues.
No, they only tested it against an i7-2600K.Really odd that they did not test against Thuban or Deneb. They did however test with a wide range of Intel chips.
The AMD 760 chipset setup does not fare well...outch.
They must have patched the BIOS for the 760 board themselves right? I can't believe one with stock BIOS would function beyond failsafe clocks with BD.
