i was looking at the Sapphire 9600xt from newegg. they have 2 Sapphires bulk and retail
bulk 151$
http://www.newegg.com/app/ViewProductDesc.asp?description=14-102-326&catalog=48&depa=1
Chipset/Core Speed: ATI RADEON 9600XT/500MHz
Memory/Effective Speed: 128MB DDR/650MHz
BUS: AGP 1X/2X/4X/8X
Ports: VGA Out(15 Pin D-Sub)+TV-Out(S-Video Out)+DVI Connector
Support 3D API: DirectX®9, OpenGL®2.0
Cable/Accessories: 1 Cable, PowerDVD, Driver CD
Max Resolution@32bit Color: 2048X1536@85Hz
and
retail 152$
http://www.newegg.com/app/ViewProductDesc.asp?description=14-102-338&catalog=48&depa=1
Memory/Effective Speed: 128MB DDR/600MHz
Ports: VGA Out(15 Pin D-Sub)+TV-Out(S-Video)+DVI connector
everything looks the same except the memory speed at 600 and 650. Ive read through the reviews they have and cant get a definate answer. one says theirs came with 650 and another 600(both reviews together)
maybe its just random? hehe and noticed the 'bulk' one is on many more wishlists even though its 1$ cheaper and comes with same stuff. If im correct retail has a longer warranty then bulk/oem?
now time for classes
thanks for any replys!
bulk 151$
and
retail 152$
