Sirje31337
- Feb 19, 2002
Can bulging/leaking capacitors cause the processor to run hotter then normal? When I play World of Warcraft the screen will mess up and I can't see anything.It didn't used to do this. I figured the CPU might be overheating. I applied a new coat of thermal paste and it doesn't do it nearly as often. For a while it would do it as soon as the game opened. But since I did it I can play for an hour or two before it does. I'm thinking that the capacitors are causing it to overheat and wearing out the paste.
