Built New Computer, U2311H No Picture
ipodlover77
Hey guys,
finally built my dads computer. running perfectly.
unfortunately a little problem cropped up. When i hooked it up to my dads U2311H monitor, the picture came up. After making sure it worked, we unplugged the computer to clean up the area. When we plugged it back in, the monitor wouldnt display anything. it just showed the blue stand by light. We turned the display off than turned it on and the picture came up. It than said auto detect and than went back into stand by. the only way we would get the display to work is to turn it on and off and even than the picture would stay for about 2 seconds.
i used two old dell monitors and it worked fine with the computer so hopefully its not a computer issue. i made sure the pins were not bent also. any ideas on whats going on?
Should i download this?
http://support.dell.com/support/dow...typeid=-1&dateid=-1&formatid=-1&fileid=385602
my system isn't listed under compatibility though.
i should also mention that its plugged into the 6450 graphics card. when i installed w7 it said it was installing the drivers also. not sure if their updated or not but still, the older monitors did work so why isn't the u23? :confused:
The first thing you need to do is test the cables and connection. Try both the displayport and dvi.
