built computer (sort of budgety)
I put together a computer using newegg and zipzoomfly, and I was wondering if I could get some input on it, or some suggestions.
To start, I have a $1200 budget (including a monitor) meaning that I have essentially $1050 to spend on the computer itself.
Here is what I, along with some friends, managed to put together.
case :
http://www.newegg.com/Product/Product.asp?item=N82E16811119106
dvd/cd r/rw
http://www.newegg.com/Product/Product.asp?item=N82E16827106055
harddrive
http://www.newegg.com/Product/Product.asp?item=N82E16822136062
graphics card :
http://www.newegg.com/Product/Product.asp?item=N82E16814130082
I was wondering whether I should spend the additional money and purchase the other version of this card, which seems to have a faster clock speed.
sound card :
http://www.newegg.com/Product/Product.asp?item=N82E16829102006
I got a sound card because I do plan on using this computer for work and games, so I need a good quality sound card.
ram
http://www.newegg.com/Product/Product.asp?item=N82E16820146565
motherboard
http://www.newegg.com/Product/Product.asp?item=N82E16813130082
I got the sli so that I could have the possibility of upgrading in the future
processor
https://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80865
power supply
https://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=373060
monitor
http://www.newegg.com/Product/Product.asp?item=N82E16824254023
by the way, my budget also includes an operating system, I was probably just going to go with windows xp home edition, but I wasn't sure.
Your input is much appreciated.
Post the part names and not just links por favor, makes it much easier for people to review your build.
LITE-ON 20X DVD±R DVD Burner with 12X DVD-RAM write and LightScribe Technology Black E-IDE/ATAPI
$31.99
COOLER MASTER Centurion 534 RC-534-KKN2-GP Black Aluminum & Mesh bezel / SECC Chassis ATX Mid Tower Computer Case - Retail
$49.99
Western Digital Caviar RE WD1600YS 160GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
$59.99
Hanns·G HW-191APB Black 19" 5ms Widescreen LCD Monitor - Retail
$159.99
EVGA 320-P2-N811-AR GeForce 8800GTS 320MB GDDR3 PCI Express x16 HDCP Video Card - Retail
$20.00 Mail-in Rebate
$279.99
Creative Sound Blaster X-Fi XtremeGamer 7.1 Channels PCI Interface Sound Card - Retail
$83.99
Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model BL2KIT12864AA804 - Retail
$45.00 Mail-in Rebate
$109.99
MSI P6N SLI-FI LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard - Retail
$109.99
Microsoft Windows XP Home With SP2B 1 Pack - OEM
$89.99
I would say go with a P35 mobo if you're not planning on SLI at some point. Gigabyte and Abit have some good options at around the same price.
Video card should be fine with the monitor you have now. What games are you wanting to play?
Perhaps a larger HDD. 160GB is pretty small these days. A 500GB at ~$100-110 is a much better value.
I'm not a huge fan of sound cards as most mobos have decent onboard sound. If you really need/want it go for it, but you could definitely save the money and spend it elsewhere like on a better CPU.
I wanted to go with the sli mobo so that I could buy a second 8800 in the future and upgrade.
Also, I think 160 gb should be plenty for me. (I was even considering getting an 80mb one for $35)
You don't need highly OC'ble DDR2-800 ram with an E4300. Go with some Corsair VS 1GB DDR2-667 sticks instead ($35 each at the egg).
E4300: 9 * 266 = 2.4Ghz, DDR2-533 << STOCK speeds
E4300: 9 * 333 = 3.0Ghz, DDR2-667 << Nice OC
E4300: 9 * 400 = 3.6Ghz, DDR2-800 << Great OC, good luck getting it!
The E4300 most likely won't reach 3.6Ghz. It usually tops out around 3.2-3.4Ghz. Also, if you plan on OC'ing, you'll need a better CPU HSF. If you're not OC'ing, go for the cheapest kit of ram you can find.
I agree, look into a similarly priced P35 board, and a larger HDD. For $60, I picked up a Seagate Barracuda 7200.10 300GB a few weeks ago, lol. Check out the hot deals subforum for some HDD deals. SLI as an upgrade path is useless unless you plan on getting a huge monitor (24" or larger); otherwise, there should always be a better single card solution, and you could sell your old card to offset the cost of the new card.
What kind of speakers do you have? If your speakers arent super high quality, don't bother with a sound card. Onboard HD Audio is fine these days.
What DX10 games are you planning on playing? If none are out yet, you may want to consider a cheap DX9 card for now. The X1950GT or Pro goes for about $110AR. Then, you could upgrade to a DX10 card when there are actually some DX10 games out, along with newer DX10 cards. If you stick with the 8800GTS, get the regular version and OC it yourself to save money.
XP home is fine. Vista is bleh, lol. I'd wait for SP1 before jumping to Vista, along with some DX10 games. Aside from DX10, theres really no point to vista besides eyecandy.
Check shipping on the Centurion 534 at svc.com. The unit price is only $35, and the shipping varies depending on where you are. Their price usually beats Neweggs, if you don't live too far, since newegg usually charges $16 shipping on top of their $50 unit price. Go with whichever is cheaper.
$159.99
good monitor i got one for my mother in law, only issue i have is a stuck pixel, but its not too bad.
hmm you guys do have a point with the motherboard, any more specific suggestions for that price range?
I found this, but not really sure if it works. I can't find a lot of boards in +/- 10 $100 range.
i have hd555's
I actually found that one myself, but I wasnt sure.
Here is what I have changed so far:
went with an xclio goodpower 500w power supply instead of the xfinity.
saved some additional money on input devices etc. and will possibly upgrade to an e6600, however I am not sure if this upgrade is worth the additional $100.
E6600 = baaad :eek:
E6750 = gooood :D
The E6750 is slightly cheaper (by like $2.00) and is faster than the E6600, so I'm thinking that would probably be a much wiser choice, haha ;)
