Building Silent PC
English Neo
In the next few weeks i'm going to be building a new PC based on the S939. I was tempted to go X2 3800 but for £127 more i can't justify it (3200+ for £100 isn't bad). Anyways, i'm not going to go SLI so i don't wanna buy an NF4 board really (more expensive which i can't afford now).
I was looking at the Abit AX8 as this has a passive heatsink and i can get it for about £70. The reason for this is i've pretty much had Abit boards - KD7A, KR7, NF-S v2.0 and now for my next one?. Any others i should concider as i haven't heard much about it. [H] done a review of it but it was the v1 and i'll be getting a v2. Wondering how high i'll be able to get my CPU if i'm limited to a 250FSB celling as i've heard about these boards. I'll be going PCI-E.
neo out
I wouldn't use an Abit board if they would pay me to do it. I have several busted Abit boards on my office wall, and while they may have gotten better in terms or quality or QA, it will be a cold day in hell before Abit gets any of my money, or the taxpayers money I am spending.
HardOCP's review states the following:
"Sadly, our retail product from Newegg was flaky at best when it came to rebooting the AX8 no matter what BIOS we used. ABIT says we must have gotten a “bad board,” and reading around in the forums, that may be very well true as we have seen some folks having some very good experiences. The ABIT AX8 is packed with usable features and comes in at a sub-US$100 price point. I just hope your AX8 does not have the same reboot issues our AX8 had, or I would highly suggest you try out ABIT’s online RMA."
The main problem I see with this board is that it doesn't support dual core CPUs, so even if you would want to use the X2, you couldn't, and when you do decide to upgrade again, simply dropping in a new chip won't do the trick.
I really don't have any suggestions other than to get an inexprnsive nF4 S939 board, the few extra quids are totally worth it in the long run, imho anyway.
Building a silent computer is expensive.
What I would suggest instead of the Abit AX8 would be the Asus A8V-E Deluxe. Sure it's got an active thermal solution on the K8T890 chip, but other brands have passive heatsinks on their boards. Get a Zalman NB47J and mount it on the Asus, you should be fine.
Thuleman said:
The main problem I see with this board is that it doesn't support dual core CPUs...
Yeah, the Abit AX8 v2.0 does which is based on the 890 chip and not the 800 chip.
I'll have a look around and see what else i like. I've already got myself a new case (Akasa Eclipse 62) and the new Akasa Evo 120... just hope they all perform silently :D
neo out
