CPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819116052
Mobo - http://www.newegg.com/Product/Product.aspx?Item=N82E16813128337
Vid Card - http://www.newegg.com/Product/Product.aspx?Item=N82E16814102719
RAM - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098
PSU http://www.newegg.com/Product/Product.aspx?Item=N82E16817182044
This'll be my first time ever putting a computer together, so I wanted to make sure that all these parts are compatible. Would be a headache if the parts came in and one part doesn't fit
Also, will this setup be able to play WoW on fairly good settings? Everquest 2? Also will CoD4 run well? CoD4 is probably the most graphic intensive game I will be playing.
Thanks in advance for the great help always given here!
