nuclearactiveguy
- Dec 2, 2011
I will be using this PC for both gaming, photoshop and Video Editing
my budget is at 1500.00US$
I live in the US , currently im in Afghanistan. so this wont be built for a good 3 months
MOTHERBOARD, CPU, OPERATING SYSTEM, RAM, PSU, VIDEO MONITOR, DVD/CD DRIVE, GRAPHICS CARD, HARD DRIVE, COMPUTER CASE.
NONE
6) Will you be overclocking?
NO, but i do want the option to. So yes, in case i ever need to
23" 1080p
March 2012
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
SATA 6GB/s and w/e to make it compatible with parts below
I do not have, but will buy along with everything. Home Premiun 64bit
___________________________________________________________________________________________________________
CASE: Full tower ATX , (7) 5.25"in bays,(1) 3.5" int bay.
MOTHERBOARD: M452-6228 ::MSI Z68A-GD55 (G3) Intel Z68 Motherboard - ATX, Intel Z68 Express, Socket H2 (LGA1155), 2133MHz DDR3 (O.C.), SATA 6.0 Gb/s, RAID, 8-CH Audio, Gigabit LAN, USB 3.0, PCI-Express 3.0, SLI/CrossFireX(4.35 lbs) CHANGED
PROCESSOR: Intel Core i7 2600, Quad, 3.40GHz (3.80GHz turbo) 95W fan
RAM: 8GB (2x 4GB) DDR3 1600MHz, unbufered.
OPERATING SYSTEM: Windows 7 home premium.
HARD DRIVE: TSD-1000H5 ::Hitachi 0F10383 Deskstar 7K1000.C Hard Drive - 1TB, 3.5", 7200 RPM, SATA 3G, 32MB CHANGED
POWER SUPPLY: ATX Power Supply 575W, 140mm Fan, single 12v Rail Diablo Tek <----- Change it??
GRAPHICS CARD: EVGA GeForce GTX560 Ti 448 Cores,1280mb GDRR5, PCI Express 2.0(x16), Dail slot SLI ready (price:299.99$)
taking suggestions on other cards too.
OPTICAL DRIVE:
Serial ATA tech, 24x DVD/CD Read and write
MONITOR: 23" LED 1920x1080p, 60Hz
NONE
23" 1080p
March 2012
OPTICAL DRIVE:
