Building off Asus P6X58D
Advent
I've been having issues with my current EVGA x58 board dropping power to USB devices then failing to POST so I decided to go with a new board and hop back in bed with Asus, who I have been using for about 8 years.
I purchased the Asus P6X58D, my rig will look like this:
Mobo: Asus P6X58D
CPU: Intel i7 920
PSU: Corsair 750 watt or Corsair 1000 watt modular (have both)
RAM: Corsair Dominator GT DDR3 1866
GPU: 2x ATI 4870 X2 in Crossfire or 2x Nvidia GTX 260 core 216 in SLI
HDD: 2x Seagate 250gb Raid 0, 2x Seagate 1.5tb Raid 0
My questions are these:
Using the PSU calculator and giving the i7 an overclock of 3500 at 1.45 voltage along with the Nvidia cards, I get a result of 559w for the recommended wattage.
Using it with the same overclock and the ATI cards I get 814w for the recommended wattage (obviously).
In the past, I used the 4870x2s and had some poor performance in a few games and some overheating problems. I'm not sure if this was due to the cards themselves or an issue with my current EVGA board. I'm fine with using the Core 216 cards by Nvidia, as they cut down on heat, noise and power consumption.
So, should I slap the 1kw and go with the ATI cards in hopes that they are OK on the new board, or should I stick with the lower Nvidia cards to keep it safe?
Does anyone see any problems that I might have with the new board and memory with this rig?
Although i think 1k power supplies are excessive in your situation due to the x2 cards you have you need a lot of extra power especially at loads. But the Corsair 750 should actually be able to handle everything but of course as heat raises your wattage output and the rail efficiency is going to go down so more room with the 1k. Additionally great choice on the board i have been working on it for a while and really the performance and smooth nature of the bios ( heatlesssun ) made a good point though that that memory is generally a hard justifies for the money spent due to the memory performance required out of your IMC is hit or miss. If you are able to run at that frequency though with a tight cas you should be smoking smooth.
Please enjoy the rest of your day.
Juan, I see you say you have been working with the P6X58D. I have a couple of questions/issues that you might be about to help me with.
First off, about a two weeks ago, one of the Intel SATA controllers seemed to die. I couldn't get any drive to work when connected to that port. I've worked around the issue as 7 SATA ports including the 2 Marvell 6 Gb/s ports. Tried different drives and cables with that port and just couldn't get it to work. I would imagine that I would have to RMA to board, just asking to see if you might know of anything that maybe I'm missing.
Also I've noticed from time to time that the BIOS seems to loose my setting for the boot drive. I have to other internal drives in my system and they both have had Windows 7 on them and are still bootable. So from time to time when I restart my machine the wrong drive becomes the primary boot drive and the only way to get it to boot probably is go into BIOS and reset it. Sometimes I have had to reset it twice to stick. I've noticed that there is another user that has posted the same problem in the Asus forums: http://vip.asus.com/forum/view.aspx...=en-us&page=1&board_id=1&model=P6X58D Premium
I appreciate any info!
I'm setting up almost an identical setup except for the fact i'm using G.SKILL instead.. Please continue to post updates to your solution.
My P6X58D setup->
P6X58D
i7 920 w/ Xigmatek 1283v. Replaced the fan because I didn't want the led fan.
(edit: Bad choice by me. I took the supplied fan and replaced it with a less powerful fan. Had to replace the fan again to get my cpu temperature under control)
6 x 2gb G.Skill DDR3 1600 (F3-12800CL9D-4GBNQ)
Corsair HX750
Asus EAH4890Top
Auzentech Forte sound card
Intel pci-e nic
2 dvd writers
3 hdds
CM 690 mid tower
4 x zm3 zalman fans
Put this together on Saturday. Only problem I had was the 8-pin eps would not reach the socket
if I routed the cable behind the tray. Big deal. Cable runs along the edge and snakes across the top. It Works.
Booted up fine. Installed w7 x64. Installed updates and started running it up. It's at 200 bclk w/ speedstep & ht enabled. Temps @ idle (now) 40-42c. Prime95 yesterday load 81-85c.
Still needs some fine tuning.
Update-
Replaced the fan on the heatsink w/ a 120x38 medium speed Panaflo, and added an old fan controller. Dropped highest cpu temperatures running Prime95 to well under 80c.
Very pleased with this board and chip.
Did you set the CPU voltage manually? If not the auto setting will generally supply more voltage than is needed.
Yes, I'm a little over 1.3 volts now. Core temperatures are a little more than I bargained for though. I ran Handbrake earlier, and was concerned at 88c. Too high. I'll back off a bit, and stress over something else.
I'm showing 4198.7 ghz in cpu-z w/ idle temperatures @ 43c.
Hey guys,
Building my new system with the same mobo and very similar parts to you guys. Switched my ram selection thanks to heatlesssun.
P6X58D (yet to buy)
i7 920 D0
Corsair H50
6GB Corsair TRX3 (yet to buy)
Corsair 750HX (yet to buy)
XFX 5870
Intel x25-M 80GB
HAF 932 case
Watching this thread with keen interest.
Just to chime in a bit.I'm running this board @4.5 on air.Memory is running at 2139 I'm using the Gskill trident. 9.9.9.24, but I'm running the ram at 9.10.9.24 2n.I just thought I would let people know a little about this board since there is a topic on it. And let everyone know whats it can do.
What CPU are you using and what voltage do you have it set? Once I got my 920 to 4Ghz I was happy as this chip is only going to my main rig CPU until the i7-980 is released.
I'm using the i7 920 and mine is not even the best of the batches to have either. My volts are as follows. Cpu is @1.47v, Memory qpi is @1.65v and my ram is @ 1.76v.
Hope this helps.
