Building new system step 1: choosing a socket
PopeKevinI
So my S478 system is on its last legs. I've had it for four years, and am on my third processor on the socket. The socket has been replaced and AGP is on its way out, so it's time to figure out what to do next.
I'd like to find the socket that will have the longest upgrade path. That way I can buy a good, high-quality mobo and RAM, and go with bargain CPU and video card now, and upgrade them once or twice in the next couple of years.
Right now I'm looking at AMD for the AM2 socket (probably waiting for AM2+). Everything I've read has it lasting until 2009 when AM3 comes out, and even then the AM3 CPUs are supposed to work on AM2--which will let me buy a CPU when I want, and change mobos to AM3 later. But I haven't been able to find out much about Intel's roadmap for sockets and what their plans are for 775 and its successor.
So what do you guys think? Any suggestions? Anything I got wrong or don't know?
I think Intel will be sticking with socket 775 for a long time. Thing is, they tend to require new chipsets to support new processors.
As for AMD, they seem to be blowing through sockets like crazy. Thing is, their chipsets tend to be forwards compatible with new processors.
Honestly, between those two, I don't know what I'd choose if future upgradability were of concern. Usually I just buy what's fast now and gut the whole thing later if something crazy awesome comes out.
I'm also fairly shocked LGA775 has lasted this long.
Well, upgrade path aside, you are selling yourself short going with AM2. Core 2 Duo processors out perform the current AMD CPUs in all categories and do so for less money. Going with an AMD processor based machine at this time makes no sense. It's likely that K8L will require a new chipset at the very least, even if it uses the same socket. So thinking of AM2 as a future proof socket is probably a little unrealistic.
Currently the newest high end LGA775 motherboards support Core 2 Duo, Core 2 Quad, Core 2 Extreme series processors, and all of the earlier Pentium D, Pentium 4 and Celeron D CPUs. The 680i boards even support 1333MHz FSB CPUs. (Supposedly)
Niether one really seems better than the other right now for longevity. I would say go with Core 2 Duo because it's faster, overclocks better, and offers more bang for your buck. Simply a no brainer in my opinion.
Well 478 lasted something like 5 years...775 is a couple years old now, I figure it's got some life left in it...but that's a good point about the chipsets. A socket isn't always a socket with Intel.
AMD hasn't gone through as many sockets as it seems like. 939 didn't last long, but AM2 looks to be here so long as DDR2 is used in systems. The only difference I know of with AM2+ is support for HyperTransport 3, which might be of great benefit later. AM3 is supposed to hit the market with DDR3.
According to everything we've been reading at work (we're all-AMD here) AM2 chips will go on AM2+, and AM3 CPUs will have memory controller that can use DDR2 or DDR3 and will work on AM2 and AM2+ sockets. That means AM2 is going to be viable for a loooong time and will allow me to buy my upgrades in small steps, which is usually how I have to do things. I have a hard time parting with large amounts of cash on the rare occasion that I have them.
I'm hoping to confirm what I've heard and read about AMD's future, and see if anyone can give me insight on Intel that might give me reason to consider them.
I'm not so much looking for future-proof as I am trying to determine a lifespan. I tend to buy an expensive motherboard and a budget processor with the intention of upgrading the processor later to top end. It's budget-conscious and has served me well.
Also, I'm not in the market *right now*, but will be probably in May. I think long-term on things like this because I know it can make the difference of several hundred dollars if I plan well. AMD is talking up a new processor core that is supposed to leap past Intel...and it will be released about when I'm looking at upgrading.
I'd been shopping C2D stuff for quite a while trying to figure out when would be a good time to make the jump to that when I started learning all this about AMD's roadmap. The problem is that the companies are so tight-lipped on certain things that it's hard to get the information I need to make a truly informed decision.
I guess my question on the AMD side should be "what will I need for an AM3 quad-core to work on an AM2+ socket?"
I'm not looking for bleeding-edge performance and I doubt I'll do much in the way of overclocking. I just don't need the horsepower for most of what I do; I won't spend the money to get a video card that needs that level of performance and gaming is the only thing that would remotely be impacted by it.
There is no guarantee you will be able to use your newer CPUs on your older motherboards. In fact, you probably can't. As far as using your old CPU in new motherboards, you probably can for awhile on AM2, AM2+ and so on. With LGA775, that seems just as likely if not more so. There is nothing about LGA775's replacement in the roadmap anytime soon. Additionally, DDR3 won't require you to abandon your old CPU. You will most likely be able to buy a DDR3 motherboard, and use your old Pentium D and Core 2 Duo's on the newer board. One advantage of keeping the memory controller off the CPU is flexibility.
Also even if AMD's current plan to keep AM2 around awhile is confirmed, there is nothing that actually is holding them to that. They can change their designs or minds at any time. Either way you are speculating on the future of computer hardware. That's generally not a good thing as it changes so rapidly. My advice is to buy a Core 2 Duo now as it will give you the best bang for your buck, and the upgrade path is no less certain for it than it is for AMD's offerings.
Hmm.... I'd say LGA775. Why you may ask? Because Intel's got a faster CPU.
Here's what I'd recommend for an overclocker:
- Intel E6400 (or E6700 if you have more money)
- MSI 975X Platinum Rev 2.1 OR Intel 975XBX2 OR AW9D-Max (only thing is the bad vDroop on the MCH for the AW9D-Max)
- Team Xtreme DDR2 667 or Buffalo Firestix DDR2 800 (both overclock to about the same clocks)
- Scythe Ninja or Big Typhoon Heatsink (atleast)
- Nvidia 7900GS (or wait for an 8800ultra//GT//blah blah blah blah)
- Antec power supply, Fortron.. etc...
- any hard drive you want
- any cd drive you want
- any case you like
That system, with 2gb of RAM, an E6400, big typhoon, intel 975XBX, and let's put the power supply at 80 dollars, would amount to around 805 dollars minus hard drives, cd drives, and cases. And the potential of this system overclocked.... would atleast 3.2ghz, if not farther. That's a better offering than any AMD system in the same price range... hell, the high end AMD CPU's can't compete against that, let alone overclock to 3.2+ (technically, an FX or X2 at 3.2ghz still wouldn't be capable of defeating a C2D at 3.2Ghz)
