antonio_checa
- Sep 11, 2005
Hi [H]ard Forum, I'm currently in the process of building a new system for gaming only and I really don't plan on upgrading it for a long time, I would like you to evaluate the specs on it and tell me where can I make some improvements for performance.
There are still 2 components I'm not fully sure of one of them is the processor bellow I put my 2 options one a single core and another one a dual core, I'm not sure yet with whichone should I go, remember my focus is gaming on this system exclusively. The other one is the PSU I want to go with PC Power and Cooling but I'm not sure if I should go with a 510watts unit or the 850watts, Main thing making me go for the 510watts is the case I have a Lian Li V1000 which from what I have read does not fit in pretty well a large PSU such as the 850, but with some tweaking and cutting here and there it could, I could consider another case if you have any suggestions but I would really like to keep that one.
Any how please gimme your honest opinion
thank you guys.
CPU:
AMD Athlon 64 4000+ 1GHz FSB Socket 939 Processor
http://www.newegg.com/Product/Product.asp?Item=N82E16819103529
or
AMD Athlon 64 X2 4200+ 1GHz FSB Socket 939 Dual Core Processor
http://www.newegg.com/Product/Product.asp?Item=N82E16819103547
Motherboard:
Asus A8N 32-SLI-Deluxe NVIDIA Socket 939 ATX Motherboard / Audio / PCI Express / SLI / WiFi / Dual Gigabit LAN / S/PDIF / USB 2.0 / Serial ATA / Dual RAID
http://www.tigerdirect.com/applications/searchtools/item-Details.asp?EdpNo=1645240&sku=A455-2124
Memory:
Corsair TWINX Dual Channel 2048MB PC3500 DDR 433MHz Memory
http://www.tigerdirect.com/applications/searchtools/item-Details.asp?EdpNo=1649411&sku=C13-3500
Graphics:
2 x BFG GeForce 7800 GTX OC / 256MB DDR3 / PCI Express / SLI / Dual DVI / HDTV / Video Card
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1466033&CatId=1560
Sound Card:
Creative Sound Blaster X-Fi XtremeMusic 8 (7.1) Channels PCI Interface Sound Card
http://www.newegg.com/Product/Produ...1&bop=and&description=x-fi&srchInDesc=blaster
Keyboard:
Logitech G15 2-Tone USB Wired Standard Keyboard
http://www.newegg.com/Product/Product.asp?Item=N82E16823126179
Mouse:
Logitech G7 931375-0403 2-Tone 6 Buttons 1x Wheel USB RF Laser Mouse
http://www.newegg.com/Product/Product.asp?Item=N82E16826104203
Display:
Dell 2405FPW
No need for a link on this one...
Hard drives:
2 x Western Digital Raptor WD740GD 74GB 10,000 RPM Serial ATA150 Hard Drive (RAID 0)
http://www.newegg.com/Product/Product.asp?Item=N82E16822144160
Western Digital Caviar SE16 WD4000KD 400GB 7200 RPM Serial ATA150 Hard Drive
http://www.newegg.com/Product/Product.asp?Item=N82E16822144423
Optical Drive:
PLEXTOR Beige IDE DVD Burner Model PX-716A/SW
http://www.newegg.com/Product/Product.asp?Item=N82E16827131338
Floppy:
Mitsumi FA404A w/flash memory reader
http://www.newegg.com/Product/Product.asp?Item=N82E16821104103
Case:
Lian Li V COOL PC-V1000APLUS Silver Aluminum ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.asp?Item=N82E16811112085
CPU cooler:
ZALMAN CNPS9500 LED 92mm 2 Ball Blue LED Light Cooling Fan/Heatsink
http://www.newegg.com/Product/Product.asp?Item=N82E16835118223
Power Supply:
PC Power & Cooling 510 SLI-PFC ATX12V 510W Power Supply
http://www.newegg.com/Product/Product.asp?Item=N82E16817703001
CPU:
or
Motherboard:
Memory:
Graphics:
Sound Card:
Keyboard:
Mouse:
Display:
Dell 2405FPW
Hard drives:
Optical Drive:
Floppy:
Case:
CPU cooler:
Power Supply:
