building new plexi case. opinion needed
Randolf
so I'm building a new plexi case for my htpc. I'm aiming to build it with as few joints as possible. but I made a slight booboo.
the front side peice is about a inch short on each end. now I can either cut the top and base to fit it. or I can cut another front/side peice and redo allowing for 3 or so inches of over hang then trim back to fit. I'm leaning towards maybe doing it again. but I also like the idea of the board fitting the case almost exact.
so give me your ideas and feedback
as long as you dont put lights init looks fine to me :) as for the whole problem issue u have me lost
orginally designed the case to be longer. now I can either redo the panel or shorten the case
