Building new pc and a unique situation
Well my mom is becoming a real estate agent, and for the past year, shes been using my gaming computer, which is obviously going to be top of the line. Well, now shes used to a "click and its there" mentality and she hates the upstairs computer which is 1ghz with windows ME and 128 mb ram. I plan on upgrading her so she will have 512 pc133 ram and windows xp. Is it worth Upgrading to 512 pc133 or should i just build her a new computer? Is the ram a bottleneck?
Build her a brand new machine because that bottleneck is really big. Also, don't use windows ME use XP, it's alot better and stable.
Yep, i am going to grab xp home for her, now she just said she doesnt want a brand new comp, so how much ram is feasible without too big a bottleneck. I know any ram more than 128 will help, and my friend has a 1ghz comp and his runs ok, so now the question is, what size chip do i buy her? 256 or 512?
New question: I found my old pc which is 1.3 ghz with 512 RDram and a radeon 7200. I wanna restart taht one but i need a new HSF. It was the VERY first generation p4 1.3 so what kind of HSF would i need?
well im tryin to pop off my heatsink so i can grab my other p4 hsf and try it on, and my heatsink isnt coming off! How do u exactly take it off again?
clockworks said:
A normal P4 hsf for about 20 bucks should suit you.
I beleive i have the older socket 423 and not the newer socket 478. Does it make a difference for the HSF?
what about just getting a new motherboard and ram instead of a new computer ?
she probably wouldn't notice that it was practically a new machine if it was all in the same case :p
clockworks said:
Not that I know of.
ARE YOU NUTS?!?!?!?
YES IT MAKES A DIFFERENCE!!!!
1. The retention mechanism on older Socket 423 Motherboards IS NOT compatible with Socket 478 Heatsinks.
2. Changing the mechanism is out of the question, the holes in the motherboard that the retension clips use are not spaced the same
3. Current Socket 478 heatsinks have a much higher retension pressure and would crack either the motherboard or the chip itself.
If you have an RDRAM board and it's P4, it's probably a Socket 423 and you will have to search for a P4 heatsink that is for Socket 423. You CANNOT use any P4 heatsink.
:eek:
The_Mage18 said:
ARE YOU NUTS?!?!?!?
:eek:
Thanks, i was browsing the egg and i didnt see any socket 423 hsf's there. Suggestions?
Chances are, the 1GHz if it was a P3 or Tualatin Celery it'd be faster than the P4.
Max out the RAM, and get her a faster HDD. (any 7200RPM would do). Then that computer would be pretty fast too. Be sure to put XP on it.
I can't believe noboby's suggested linux, it's way faster, and if all your mom is doing it surfing, there's really nothing to "learn"
I'm sure there's some Windows only real estate applications that she will want to use. I'm not into real estate but I just have this feeling there are some programs that make the job easier.
