Greatone123
- May 10, 2006
I'm sure you've seen these what PSU should I get, how much power is needed... blah blah blah... mine has a slight difference to it tho...
Building a WHS for the first time, read so much in here about it I basically convinced myself it's a must have.
Case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811219035
I personally don't need that much space to justify the big 4220. I figure 8TB is more then I'll ever ever ever need, I'll prolly turn on duplication for everything, my current storage consists of 3x 250GB HDDs... and it's not near full. I just want the back up features, and ease of use that comes with the WHS.
Controller Card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16816115057
knowing the new norcos use SAS, I figured might as well use it. It has 2x MiniSAS connections so it kinda fits the bill.
HDDS:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136317
Do I really need to explain why? Their green and hold 1TB... I'll start off with 2 or 3 of them and work my way up to 8.
I've got a BioStar 790GX board and a AMD 4850e layin around I'll use, low power and well I already have it so price is ok, has 2x PCI Explress x16 slots, so I'm hoping I can use one for the HP Card.
BUT! after all that, the actual question...
I know what normal sized PSU's I like and use... but I've never looked at the 2U PSU's... what do you guys recommend for that? Some brands in there I'm not real familiar with. I prefer to buy from Newegg, just because of familiarity...
Case:
Controller Card:
HDDS:
