Ok, I am excited about finally getting into PC gaming. I do need some help picking out some components because I am still new to this and I'm not sure if everything will fit together.
Keep in mind that I want to spend as little as possible, and that I'd like to keep upgrade it in the future.
Question: When does DDR2 come out???
CD/DVD Drive $22 Sony CD/DVD drive - I don't need a dvd burner!http://www.newegg.com/Product/Product.asp?Item=N82E16827101131
$115 WD Western Digital Caviar SE16 250GB 3.5" SATA (Question, how much of a difference is there between 8MB and 16MB cache?)http://www.newegg.com/Product/Product.asp?Item=N82E16822144701
$162 Corsair 2GB DDR400 - is this a good choice? Any other RAM that might be slightly cheaper??http://www.newegg.com/Product/Product.asp?item=N82E16820145505
I plan on OVERCLOCKING sometime in the future when my processor becomes too slow, is that a good choice RAM for overclocking, if not then what is?
$233 Athlon 64 3700+1GHz l2 level 1mb - I think this is an excellent choice.
http://www.newegg.com/Product/Product.asp?Item=N82E16819103539
much better deal than the 4000+!!!!
Monitor - I plan on playing games at 1024x768 and sometimes also at 1600x1200, would like an 18" viewable inch flat screen. I have no idea what kind.
PSU - I need one that will support two 7800GTXs,
$90 PSU Antec Truepower TPII http://www.newegg.com/Product/Product.asp?Item=N82E16817103931
7800GTX - waiting until it drops down in price, couple months, then buying it, then maybe 12 or 18 months later getting another 7800GTX for super cheap (if they are still making them which they should).
Case - already have one picked out, dont need advice on that.
