Building from scratch
§pix
I am going to try to build a WC system for my MOD that I am currently doing. I have been looking around the sites and so far I have come up with these:
Next-Cool W-Zero X2 Double Radiator (Black)
Bay Reservoir 1/2" Barb
Swiftech MCP-600 12Volt DC Pump Version 2.0
ClearFlex 60 3/8ID x 1/2OD Tubing
HydrX Extreme Duty Coolant Additive
Danger Den TDX AMD XP/MP Waterblock (AMD Socket A/462)
Swiftech FBK525 1/2 inch Fill and Bleed Kit
This is the first MOD and WC system that I have built and if you have any suggestions on what to buy and what not to buy for the WC system feel free to tell me. I am open to Ideas and suggestions.
Imitation
You're gonna do the bay res and the fill bleed kit? I don't know if thats a very good use of your money. I'd say one or the other.
§pix
It is one or the other. I was looking for opinions on which one was better. Which was worse. I didn't write this in the original post though. I forgot to.
