I have a little project where I'd like to have four client computers to simulate load and do testing against a server. They'll have to be small; I want three or four in a pile, connected to my network and a KVM to a single monitor and keyboard.
I was thinking about buying used OptiPlex machines, but they seemed expensive. I've also heard about the machines that I'm interested in -- say, the GX270 or GX280 -- having bad capacitors.
Looking at building my own, I've found the IN WIN IW-D500T.240BFU2AD case. Is this any good? It's the cheapest case that doesn't have miserable reviews at NewEgg about the crappy build quality, or parts cracking, and so on. Would you recommend anything else
I'm going to use 3500+ or 3800+ Athlon 64 X2 processors.
I've chosen the ASUS A8N-VM motherboard, I think. Is there another micro-ATX motherboard with onboard gigabit and a decent video chip that you'd recommend? The A8N-VM supports PCIx16 in case I do want to add "real" graphics cards.
Can anyone recommend a better motherboard? Cheaper, with the same features?
Even with these parts, I can put togethre four machines and throw in the KVM switch for about $2000.
I can find lots of five GX260's on eBay for about $1600 shipped; how would they compare to this build? They're not going to be dual core, and most of the used machines don't have a gig of memory. Is there a way to get trim costs on this build?
