potroast said:ASUS PC-DL is a good cost-effective board for dual xeons. It's hard finding good boards for workstation use (good AGP and what-not).
Bling said:while the pc-dl doesnt support 800 fsb it is possible to reach it. i currently have 2 3.6ghz 800 fsb xeons on mine with dual channel ddr400. of course they started out as 2.4/533/m0's
dbc said:What's your budget?
Bling said:just buy an asus ncch-dl and run those 3.06 at 800 fsb. you could probly get a good 3.6 ghz out of them aswell. Im sorry to say but i have done the same thing with 2.4's and they cost alot less. a prestonia xeon at 800 fsb outperforms a nocona xeon. it also runs cooler. 64 bit means very little right now anyway. most poeple dont understand how cheap a dual xeon rig could have been. if you remember a few weeks back there was a deal for a pair of 1.6 ghz low voltage xeons. they pretty much overclock to 2.8ghz and at 800 fsb aswell. all that for 120 dollars. but yoou need a mobo aswell , an asus pc-dl costs 150 dollars and is capable of all that. now that is two xeon proccesors and a capable mobo for only 270 dollars. next just use some ddr400 ram and reuse your hdd and cdrom and video card and you have a dual xeon system for an extremely cheap price. and since the xeons have an 800mhz fsb and run at 2.8 ghz p,lus it performs aswell as a p4c in gaming.
y3yar3a said:Bling
its a good point u have but theres no reson to overclock a xeon that would just be f... stupid ,xeons are for servers and workstations and thye are already fast enought faster then crappy pent 4 so whne u get a dual xeon thats even faster so there n point of overclocking it cuz with dual 2.4 xeons u wont have any lag and i mean any lag cuz my boy got a comp wiht a pair of dual 2.4 xeons his crap never lagz he plays games at the highest resolution as he can and i never see his comp lag so if his never lags at dual 2.4 a 3.06 will just blow his doors off completely .
IceWeasel
the price is not bad
the xeons 2.4 are cheap there like 180 bucks a pop and the mother board is like 200 bucks , the power supply is 114 bucks
if u want to find cheap comp parts the best site i know of is
http://www.pricewatch.com/
got some really good stuff in therecheck i out
sdadept said:the heat factor from the xeons is a real problem for me too. I am actually considering maybe using a watercooling solution because they are so bad for heat. And I've never considered using an alternative solution like that in the past.
