I'm starting my studies for the CCNA. Now after reading a few articles on 'how to prepare' and other equivalent topics, I've decided to start building a Cisco Home Lab. This lab will later be expanded with gear for hands-on experience for CCNP and eventually the CCIE.
As I was reading up on wich products to start with I came to this contradiction. Well... actually, something I think is a contradiction, and something I hope you will explain to me.
I came across this article: http://certcities.com/editorial/features/story.asp?EditorialsID=81
Nice article, and it says in the 'Routers' section that the best choice is a 26xx router.
Later on when I read this article:
http://www.thebryantadvantage.com/HOME LAB Suggested Topologies.htm
I began to look at specifications for my cisco products and turns out that the better choice is de 2500 series...
Anyway, I wrote down a list of things I'm going to buy: (first things first)
Those ISDN ports come in handy when inserting a ISDN simulator, which I might add later.
Anyway, is it better to switch to newer 2600 series routers or not (and in both cases, why?)
Any changes that would make the lab more complete foor CCNA with later expantion for CCNP and CCIE?
Thanks, Black Box
- 2 2503 Cisco routers (2 serial ports, 1eth port, ISDN port)
- DTE/DCE cable (for inter router connection)
- 2950 Cisco switch (via eth port connecting with the 2 2503 routers)
- 2520 Cisco router (4 serial ports -> frame relay switch)
- 2 DTE/DCE cables for connecting all routers to relay switch)
Thanks, Black Box
