Im trying to build longer wires for an NPI Keystone Switch to the Capstone subsections.
I need atleast 25 feet between the Keystone and Capstones. The datasheet says "64GBPs Crosspoint Switching Fabric". The closest thing to a datasheet i could find on the IC that controlls the port says that it runs at 1.6GHz(no mension of the actual transmission frequency). The port has 4 transmit pairs and 4 recieve pairs, in all 16 wires.
I built a proof of concept model at about 25 feet with two lengths of cat5e. It Seem to have worked but I didnt have enough computers to load down the switch.
Should I step up to cat6? Or will it even run at full speed with the length and/or type of wire I'm using? Or is there an easier way?
