OK. I am in the process of building a new PC. Here is the setup.
Thermaltake Xaser V Damier V6420AU Silver Aluminum ATX Mid Tower Computer Case
Antec TRUE550 ATX 550W Power Supply
2x BFG Nvidia 7800GTX 512mb sli
AMD X2 4800 processor
2gb (512mbx4) Crucial Ballistix DDR2 ram
Sound Blaster Audigy 2zs Gamer
2 WD Raptor 36gb HDs
2 Lite-On SOHW DVD-RWs
What I wnat to know is this: is it possible to install an internal liquid cooling system (or some interal/external hybrid that is permantly attached to the tower) that can cool the two Vid Cards, the ram, and the processor? Will it be too tight in there, or is it possible? If it is possible, what peices do I need? I want to purchase the parts from Danger Den, but I don't know what peices I should I get.
I know I need
waterblocks for the processor, vid cards, and ram
tubing
reservoir
radiator
and pump
But I don't know which ones or anything like that. Can anyone who has done somthing like this perform please inform me on what i need and wether I will have any problems install the system in that case.
I know I need
tubing
reservoir
radiator
and pump
