digitalgunfire
- Aug 26, 2008
Current setup is in sig. I'm thinking about tossing another 570 in SLI and buying three small-ish monitors for nvSurround. 22-23" will probably fit on my desk.
What is the current suggestion for a decent quality, preferably IPS, monitor for this purpose? I had the NEC EAWMi on my list for a while - has something superceded it? Looks like it can be had as cheap as $250 online now.
I don't need the 'best of the best' - I don't want to spend a fortune. On the same token, I don't want to spend $750 when I could spend $1000 for something twice as good.
What do you suggest?
