Insane Lunatic
- Sep 7, 2004
Hi guys! I'm a newb here and I'm planing on taking on a huge project.
I'm designing an aluminum case from scratch. been working on plans & innovations for the past year. I'm ready to start building... I think..., but I'm not experienced in working with metal.
Features will include:
- 100% completly tooless
- mobo latch design
- mobo tray opens up with the right side panel, along with the back and top panel.
- HD cages and power supply attached to right side panel
-- you can open the case up and have complete unobstructed access to all components, withount unmouting a single wire
- all components have fans that draw air out of the case
- QUIET
That's the plan anyways!
What kind of tools do I need to work with aluminum?
I'll be aquiring some scrap aluminum to experiment with first.
When this case is done, it will make a CoolerMaster look like last years technology! I'll post updates when I get started.
Anyone have experience working with aluminum, I would greatly apreciate any advise! Or if anyone has any other suggestions?
Thanks!
- mobo latch design
- QUIET
Thanks!
